The correct air pressure in a tire is directly related to the weight upon it. The rear tires on my unloaded 1 occupant (170 lbs) hatch is quite light compared to the load on the front (engine, transmission, etc).srellim234 wrote:Why would you want to run less when that leads to a loss of mpg and higher tire wear?
Beg to differ, but I worked for a Goodyear tire dealer. I saw all the problems and misconceptions concerning tires. Like I said I replaced the stock tires with Toyo 205/70/15's which are rated to carry a considerably heavier load, thus allowing for a bit less pressure.marleyfan wrote:The tire pressure sensors are designed to tell you when your tire pressure is too low. Dude....your pressure is too low. If you're not going to heed the warning then don't blame the sensors. If Nissan felt the front and rear tires should have different pressures they would have put that on the door sticker even for the stock tires.
If you worked for a tire dealer and are so knowledgeable about all things tires then why did you come on this forum asking that question in the first place? Not trying to be an a-hole but it seems to me that you should already know the answer.boxcarbill wrote:Beg to differ, but I worked for a Goodyear tire dealer. I saw all the problems and misconceptions concerning tires. Like I said I replaced the stock tires with Toyo 205/70/15's which are rated to carry a considerably heavier load, thus allowing for a bit less pressure.
It is by continuous human contact and interchange that one becomes wise in the first place.marleyfan wrote:
According to my calculations I'm getting 8% less revs with the 205's. The tire size change is an attempt to get some more overdrive out of the grossly inadequate 6 sp transmission.scar wrote:205/70/15 is almost 150 rev. per mile more than stock, how bad does that screw up your speedo.
I do agree with you on the psi based on load though. I do that with the tires on all three of my trucks. You can get a good idea on how much air to run by going to a flat parking lot and make a line across your tires with chalk and driving straight a few feet and see where the chalk is wore off. Off in the middle, let some out. Off on edges, put more in.
All that said, I do run 40 psi all around in the stock tires of the 180 V car with no weird wear.
Yup you're right. When your speedo reads 60mph you're actually going 64.5mph. You may want to keep an eye open for the black and whites.boxcarbill wrote:According to my calculations I'm getting 8% less revs with the 205's. The tire size change is an attempt to get some more overdrive out of the grossly inadequate 6 sp transmission.
The thing that has me worried...after three TPMS failures in 18,000 miles...is whether this will continue BEYOND my warranty period. It's one thing to take the time to haul the car down to the dealership for a free reset, it's another if they charge me $50 every time they "fix" the faulty system.alonsorules8 wrote:It is federal regulation in all 50 states that all vehicles sold after July 2008 must have a tire monitoring system. If the state you live in requires yearly inspection your vehicle will not pass with the tire pressure light on.
since you have a brand new vehicle Nissan will replace the sensor under warranty and clear the TPS light on your dash.
