evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Feb 24, 2016 11:31 am
Depends on the offset. The 06-08 Grand Touring (like mine) and the 07-08 Nismo came with 18x9 front and 19x10 from the factory and will fit any 03-08 350z.These wheels are both +30mm offset, honestly not a lot of choices out there in the correct offset but spacers can be used to make more common offsets work. As for tires 285's will fit on all four wheels without rubbing at stock height, it's very tight on the front. No rolling, no flaring it just fits. Now if you lower the car all bets are off. Narrowing tires will give you a bit more play room but I'm an autocrosser and I always want as much tire as I can fit.
