First of all, thanks to PalmerWMD for putting my problem in the forum. Thanks also to AZhitman and Heath for the words of encouragement........I need this right now! And, DougQ45, I'll take your idea as a backup plan. I really think that with DAEDALUS' help I can lick this thing.
RESPONSE TO DAEDALUS:
2) Originally, I was only going to replace the guides and tensioners. When I heard the funny noise, I decided to be safe and check things out and replace the chains too as long as I was there. This was over Thanksgiving, and I really think it was a"not-so-loud" clicking. I had wired the chains, but maybe not tight enough. There was no problem with the right side. This was also the point at which I noticed the crank angle sensor seemed to have changed position, futher leading to my desire to be cautious.
When I got the upper timing cover off, I inked both camshaft sprockets where they were in relation to each other. I could not see the mating marks on the old chains until I had them off, but it was easy to line up the mating marks on the new chain on the right side without haveing to move anything. Just got lucky, I guess.
The left side was harder, and kept jumping on me ("loud clicking"). Finally, I was able to line all of the marks up on the left side and found that the inking marks I had made were in the same place as before. That must mean that the chain had not actually jumped time as I feared.
When checking the mating marks, I was careful that the driven side of the chains were under tension.
4) and 5) Let me see if I can clarify what I was trying to convey in my original message.
As I was turning the engine over slowly, it was necessary to stop and get a new position to continue turning the crank. When I paused, the right side would occasionally go slack or tight while making clicking noises, apparantly equalizing the tension on the valve springs. The left chain did not exhibit this same action, and I suspected something was amiss.
Because of this, I tried to move the left side intake cam using the cast-in hex shoulder. I was able to do so through about 10-15 degrees with moderate resistance and without any movement of the cam sprocket. When trying this same thing on the right side, I immediately came up against the tension in the timing chain.
After reading your post, I now think this might be caused by a problem with the variable valve timing mechanism on the left intake cam. Its my understanding that this device works on oil pressure. Is it possible that when the engine is running this situation will correct itself?
I did notice that the exhaust cam sprockets had two marks, 180 degrees apart. However, they were labeled as "RE" and "LE" on one side only, which was in the up position, and that both exhaust cam pegs or locating pins were also in the up position. I considered that the left side exhaust cam might be 180 degress out, but the slotted drive on that cam for the crank angle sensor is an offset type and it was therefore easy to see that it was in the correct position.
I also checked the position of the cam lobes for Number 1 (left bank) and then Number 8 (right bank) cylinders and satisfied myself that the exhaust lobes were properly spaced. As I mentioned in my first post, the relative positions of the intake cams between the left and right banks seems to be different. Maybe this is due to the left side variable valve timing issue noted above. I tried diagrams of a 4-cycle valve train and concluded that I can easily confuse myself!
Bottom line:
a) All timing chain marks are OKb) The engine turns through all four cycles with no interferencec) The crank angle sensor is 10-15 degrees off (just a guess as to how much)d) The left side intake cam can move 10-15 degrees independent of the cam sprocket (again, just a guess as to how much)e) I did check the basic timing by temporarily fitting the lower timing cover and crank pulley, and I double-checked that number one piston was at the top of the cylinder by puttng a screwdriver down the sparkplug hole.
My apologies for being so wordy, I just want to get this right. Have I been studying? You bet. I have copied about two inches of material from previous posts on this site on all kinds of topics. Absolutely invaluable!
