nismopu »
https://forums.nicoclub.com/nismopu-u29994.html
Tue Mar 10, 2009 4:39 pm
buy an OSK timing chain kit. If your nissan was made before 94 suppposedly it will not have metal backed guides. This I feel is here say but might be credible. I dont know, I just pulled a 90 KA24e apart from a 240sx that had never been cracked open and it had metal backed guides. If yours is missing completely it will wear into your timing cover! I have seen the oil pump drive be damaged from this and the oil pump itself, not to mention the spun rod bearings you will have when it cuts into the coolant port. change it with an OSK kit and run a check valve style oil filter. peace.
