vishal »
https://forums.nicoclub.com/vishal-u16196.html
Mon May 10, 2004 7:19 am
Hi,After searching the web for a decent Infiniti J30T forum, I chanced upon this great website.I own a 1993 J30T with 265K on it. The car has been running very well with a couple of major repairs. I have owned it for 3 years and driven about 90K.Had very little service of the car when I purchased it. Have tried to keep well maintained. Recently though, I have benn having some problems. It started 3-4 weeks back. Used to be intermittent but then became pretty regular. While driving, the engine would turn off sometimes. Used to happen on low RPM's (when stopped at red lights or driving in a traffic jam) and only when it was humid but it developed into a major problem where it didn't really matter what the weather was like.The car wouldn't start once it lost power. There was a lot of hesitation when it did start up and if u gave it some gas, there were black fumer coming out of the tail pipe(serious black fumes) and the car would vibrate. If you kept at it (let it idle while in park with hesitation) the engine would rev up on its own in a couple of minutes. If you put it in drive, sometimes the car would be ok and sometimes it would lose power again.I finally took it to a mechanic (the first one I encountered) and the guy said that the timing belt might need replacement. The car was giving problems just starting up now so I told him to go ahead. The car seems fine now but I have been trying to do research on the problem and I can't say I have seen any of the posts with a problem like mine. Just wondering if the shop "took mefor a drive" or could a problem like this be related to the timing belt issue. I haven't replaced the timing belt since I have had it.I know this is a long read but hopefully I can get some answers since this site seems to have a lot of J30T specialists.
Thanks again for all the help.Cheers
