Tiida projector HID
Nismo Tiida
Car: Nissan Versa
Does any member knows if the projector HID headlight from Japan version can fit into Versa? Also the tail light?
Mr. LS
The beam pattern will be wrong and dangerous so no.
blindsnyper
Car: 2007 versa
Mr. LS wrote:The beam pattern will be wrong and dangerous so no.
Mr. LS
blind_snyper wrote:
Canada and the US are both LHD countries whilst Japan is RHD thus two different beam pattern castings. If you get J-Spec headlights, either one of two things are going to happen, 1. They are aimed properly to spec at 25 feet from the wall, the right hand side of the RHD beam is 1.8" lower than the height of the center of the projector of the floor on a level surface. or 2. You will compensate and aim them higher due to the incorrect beam pattern so that you will be able to see, and blind oncoming traffic, and have the right side of your beam pattern acting like a high beam.
Do some research, and you will learn what I mean.
As for the taillights, they will be a direct swap.
reyes1212
Car: '07 Nissan Versa Super Black
What do the other taillights look like? Aren;t they sort of the same?
