tII injectors
8ggalant
Car: nissan cefiro
well here's a cheap alternative to getting 550's...but then i remember'd that they are HIGH impedence....is there a way to use these...has anyone ever tried it???
rexhunta
Car: '95 Mitsubishi RVR ( 4G63T and AWD thanks !)
MY10 Forester X LE
find a ballast resistor from something like an RB20-25 maybe even a Sr, or wherever those injectors belong too.. thats how you drop or make an engine run higher or lower impedance injectors..
E.G. to run RB26 injectors in an SR, you'd need the ballast resistor pack from a r32 gtr to make the impedance right.
Pete
biosehnsucht
actually high impedence injectors would not need a resistor at all.
however, im not sure what other tuning adjustments would need to be made as the stock ecu injector turn on and off time would be incorrect for the injectors, you'd be unfueling some.. of course thats tunable in way or another..
8ggalant
Car: nissan cefiro
sounds like a PIA...hmmmm
float_6969
You'd just have to bypass wire the resistor pack. You'll have to retune by some means or another ofcourse.
8ggalant
Car: nissan cefiro
well ima gonna do sum research (as i am a noob to electronics and wouldnt know HOW to bypass the resistor box lol)
a buddy of mine is a rotory nut and has rx7 injectors fallin outta his rectum....so this would be a CHEAP alternative w/ a little modification
rexhunta
MY10 Forester X LE
biosehnsucht wrote:actually high impedence injectors would not need a resistor at all.
But the Ca runs low impedance injectors.. how would this work without destroying the computer?
