Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri Sep 26, 2003 4:33 am
If tie rods are gone have you checked the kingpin and its 2 bearings.Kind of system that all wears together, upper links, lower A arm bushings, sway bar bushings, tie rods inner and outer.
Need more than a wrench, plus relignment every time something in lower area that controls the toe parameters is changed.
A quarter of a turn is significant in toe!
