C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sat Jul 26, 2003 7:50 am
You want to connect the boost signal line from the side of the wastegate to the signal source. The source can be any part of the intake that sees boost pressure. A signal from the manifold will be best for spool-up, but a signal near the turbo will respond to pressure faster keeping boost spikes to a minimum.
