sims »
https://forums.nicoclub.com/sims-u3780.html
Fri Feb 14, 2003 10:15 am
well here's the thing, your going to be able to make a lot more power with a turbo then you would with the same car in N/A form, theoretically, if you could have a 240 make the same power NA as it could Turbo'd, NA would be better. Its more predictable and the power curve would be much more smooth then with a turbo, you would defiantly have more control of the car around a little auto-x course, where most of the time your in you lower RPM’s, boost kicking in with a big serge of power in a tight track isn’t a good thing.
I’ve never seen this myself, but I’ve been told from a few friends that when they watched a few KA-T’s auto-x again some the close to stock KA’s they barely pulled better times.
