rmezz13 »
https://forums.nicoclub.com/rmezz13-u82416.html
Thu Sep 25, 2008 1:15 pm
Most of your "bugs" have been worked out by now. The transmission issue with the manuals i believe was a problem all the way thru 2005 - its kind of hit and miss. Your warranty and recall issues have all been taken care of by now.
One thing to consider, is these cars are noisy. There are so many noises and sounds that it always sounds like something is going wrong but you'll find by the performance of the car, clearly nothing is wrong .Now, that being said, there aren't any noises like motor ticking or knocking, if you look at an 05-06 be sure to check the oil level (some had oil consumption issues - piston rings i believe are to blame). Be sure on all test drives you gun it hard - i do with every car, so if it fails or is hiding anything, it will show its true colors then.
Let us know what you look at / get.
edit: and as far as history checks, email me the VIN and i can help (but only for a limited amount of time left).
