180weaver »
https://forums.nicoclub.com/180weaver-u54414.html
Tue Dec 18, 2007 1:11 am
I have a 90 ka24e and have purchased several, about 3 different thermostats. stock and below stock temp and they seem to work for about one use and then no more. I actually removed the thermostat and no more overheating, but not sure how long the injectors will last since the temps are so low. Fortunately I have the nistune ecu and can adust the engine temp to compensate for the injectors. Not sure why the thermostats didn't work though, maybe some junk that clogged the jiggle valve, but if you don't have to deal with cold temps, then just remove the thermostatAloha
