kbflip02 »
https://forums.nicoclub.com/kbflip02-u80964.html
Wed Apr 02, 2008 3:46 pm
any ideas???i was told it may be a temperature sensor of some sort...either that or the knock sensor which i plan on replacing soon anyways but im not sure...also if anyone has the Gates part numbers for the water pump, power steering pump, and tensioner for the timing belt it would be greatly appreciated...since im doing the timing belt anyways i might as well do these as well...
on another not would a cooler thermostat(170 as opposed to 180)cause the J to overheat and lose performance in hotter temperatures...any ideas would be helpful....
lastly i priced a transmission from level ten and i was told 3260 for everything not including taking it out of your car and putting it back in...thoughts???
if i dont fix this temperature thing soon i might as well just have my ECU reflashed and attempt to have them correct it while its being flashed...im pulling my hair out trying to guess...will pull the codes tomorrow though
