The visor is too short!
ErikM
Car: Nissan Versa SL
Now that the sun is starting to come out I'm finding that the visor is totally inadequate. Waaaaaaay too short. if I contort myself I can avoid being blinded by the sun, but if there is a replacement or an extension that works I'd rather have that.
Does Nissan make one, or is there somewhere I can find one that won't be hideous (something that will match my tan interior)?
Knightro2
Car: 2008 Nissan Versa SL
I agree, if anyone knows where to get one I'm for it.
Even though I hated my '98 S-10...that was the one good "engineering" thought put into it. My visor would be normal size near the windshield..but if I moved it to the side window it had a little slid out portion to make up the distance.
Modified by Knightro2 at 5:17 PM 4/16/2008
ErikM
Yes...I'm disappointed there isn't a slide-out extender. I think most automobiles have that anymore.
srellim234
Car: 2007 Nissan Versa SL hatch w/CVT
(sold 08/2011)
2008 Toyota Prius
(purchased 04/2016)
Here's a clip-on visor extension:
http://www.drivingcomfort.com/...37124
The same thing is actually cheaper through amazon.com
http://www.amazon.com/Trillium...r=8-2
marleyfan
Car: Black Versa SL, CVT. Tech Package, 35% Tint, Window Visors, Spoiler
Not only is it too short, its too wide. When I flip it down it covers half the windshield leaving only the lower half to see thru. Good luck seeing traffic lights.
ErikM
srellim234 wrote:Here's a clip-on visor extension:
Oooh - that's nice.
I should have been more clear - I meant it's too short long-ways. I need it to extend farther when I have it flipped to the side so it covers the length of the driver's side window.
xtwoonamatchx
marleyfan wrote:Not only is it too short, its too wide. When I flip it down it covers half the windshield leaving only the lower half to see thru. Good luck seeing traffic lights.
exactly, not only that, but my passenger had hers down and i was in a parking lot, almost turned into a car that was completely invisible behind it =\ so it was about that time she stopped putting on makeup =p
srellim234
(sold 08/2011)
2008 Toyota Prius
(purchased 04/2016)
ErikM wrote:
Oooh - that's nice.
In that case, try this one for $8 US. It isn't a match for your interior but functionally it should be exactly what you're looking for.
http://www.amazon.com/Get-Orga...tle_1
I hope this helps you.
keanucosmo
My biggest issue is that the visor is too thick. Things that use visor clips usually won't work on the V.
TheRussianBull
Car: '07 Nissan Versa
I really dont have a problem with it, you guys should see the visor in the VW R32... that think is narrow and short... its half the size of a notebook lol
ErikM
That looks like it will work! Thanks so much.
keanucosmo wrote:My biggest issue is that the visor is too thick. Things that use visor clips usually won't work on the V.
This is true. My garage door opener doesn't fit on it.
CodeRed
Car: 2008 Nissan Versa S MT
You think it too short? Really? Every time I have mine down then get back into the car i end up wacking my head on it.
srellim234
(sold 08/2011)
2008 Toyota Prius
(purchased 04/2016)
You're welcome. Please let us know how well it works.
frankoV
Car: 2008 SL Sedan, Magnetic Grey, CVT
CodeRed wrote:You think it too short? Really? Every time I have mine down then get back into the car i end up wacking my head on it.
Simple solution, Red: put it up before you get out of the car
Don't know how they could have lenghtened it with the rvmirror in the way (right in the middle -- what were they thinking?), but if you have the seat back then the sun can easily hit you when it shines from the side.
