Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Mon Jan 31, 2005 3:07 am
Pulling the inlet fuel line is one way [after you have run the engine to exhaustion with the fuel pump fuse removed] but the returnline line may backflow and the rail still has some volume.
Why we almost always pull the plenum off and the fuel rail as a unit [to the bench] for replacement of parts [injectors, o-rings, hoses].
Saving a labor buck with individual on the car injector replacements is dangerous and tricky. If one is bad the others are usually impaired.
Fuel flow is 8,6,4,2 [rubber hose across front then] 1,3,5,7 to FPR then return to tank.
