Acrylic paint conditioner 1. Never Dulls 2. Can be applied in hot sun 3. Can be applied in freezing temperature 4. Does not yellow 5. Does not have to be removed 6. Requires no buffing 7. Does not harden 8. Does not create swirl marks 9. Pure liquid 10. Rust resistant 11. Easy one step application 12. Eliminates the need for Clay 13. Eliminates the need for polish 14. Creates a shine within the paint 15. Is absorbed into the paint 16. Creates no debris or waste 17. For “Scratch Shield paint” 18. Preserves factory finish 19. Does not trap and hold particles 20. Has built in cleaning agents 21. Eliminates the need for soap 22. Protects Chrome & wheel from road salt 23. Conditions and shines black vinyl trim 24. Conditions and preserves clear headlights 25. Deoxidizes and restores color to acrylic paint 26. Conditions & replaces essential elements in paint
27. Takes less than a half an hour to apply 28. Unique in the market 29. Non abrasive 30. Efficient, 95% goes in the paint 5% in the towel
common Wax
1. Dulls
2. Cannot be applied in hot sun
3. Cannot be applied in freezing temperature
4. Yellows
5. Must be removed
6. Must be buffed
7. Hardens
8. Creates swirl marks
9. Solid and solids suspended in liquid
10. Has no rust inhibiting properties
11. Two stage application
12. Creates a need for clay
13. Creates conditions that require polish
14. Creates a wax shine on top of the paint
15. Sits on top of the paint
16. Wasteful and messy
17. Not for “Scratch Shield”paint
18. Replaces factory finish
19. Traps and holds particles
20. Has no built in cleaning agents
21. Creates a need for soap
22. Designed to be used on painted surfaces
23. Not designed for use on black vinyl trim
24. Has no conditioning effect on headlights
25. Is not a deoxidizer or color restorer.
26. Does not condition paint
27. Can take hours to apply
28. Common in the market
29. Can be abrasive when hard
30. Inefficient 95% winds up as waste
Source:
http://www.ibc34.com/VaporWax.html
