Terrible Belt squeek
Two-Fortee
Car: 180sx.
My alt/water pump belt is sqeaking bad. At least I'm assuming its the belt anyway. it seems to be pretty tight, and my mechanic neighbour told me to put some soap on it. Tried that, and it worked at first. Now its back. I tried it again, and no luck. Its squeaking like a mofo. Its bad at idle, and its bad for about 2 or 3 minutes, but thats about it. IF I'm at WOT around 2500-3000 rpm, it will go away completely. When I downshift, it always squeaks though.
Im right about to go out and buy belt wax from canadian tire to see if that fixes it. Could it be something more serious tho? Water pump? Alt? Car only has 45000 origonal clicks, so I'm hoping not...
Thanks for the help.
Ca_Silvia
Sounds exactly like my alt belt, same symptoms and everything i had to tighten that thing alot more i ever had to tighten a belt.
float_6969
Have you tried just buying a new belt? They're like $10.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
float_6969 wrote:Have you tried just buying a new belt? They're like $10.
thats crazy talk.
Two-Fortee
Car: 180sx.
Just making sure its not something serious here like a water pump. belt wax stuff kinda fixed it today. Will do it for about the first 10 seconds of driving. I'll put more on, maybe tighten it a little more...
Rin5
Car: 1990 240sx CA18DET, 1990 240sx SE fully auto (Daily)
its only a few days old so ill post...
to change a belt...you just loosen the tensioner with a 12mm and it will loosen right? and if it wont budge, do i use a breaker bar of some sort? cuz i tried last night since my belts squeal like pigs but the alternator will not move ... this applies to the PS belt too right?
Two-Fortee
Car: 180sx.
theres a bolt that holds the alternator in place on a black bracket. Take it out, then u can move the alternator and take out the belt..
jt15833
Car: 95' 240SX
there is also a large 14mm bolt on the bottom of the alternator. Although not 100% necessary I usually loosen this also.
turbo-sil40
Car: 00' Land Rover Discovery, 1990 nissan silvia conversion coupe with CA turbo swap
Take the belt that you have to Advanced Auto parts and fined one that is just a little smaller and put it on, my did the same thing and thats what I did and guess what no more squeaking. I will go and check the belt size for you and post it.Go to Advancedauto.com and type in this number in search 5040330 That should be the Dayco poly-cog belt and that is the one that I use and it works perfectly nice and tight no squeaks
Modified by turbo-sil40 at 4:45 PM 10/9/2008
