hey guys when i get the temp sensor code i just need to make sure the connections are good and replace the temp sensor if needed right?side note with the old KA24 i had the same code come up then when i put the CA in i still get the code is this just coincedince? also what one is the temp sensor the red one with the 2 prongs or the one next to it with the single prong
is there any thing else that can cause thisthanks
