SpecDRacing »
https://forums.nicoclub.com/specdracing-u28175.html
Sat Sep 27, 2008 1:41 pm
I'm with Beancooker. If your Z is out of warranty, and not able to get an extended manufacturer warranty, then by all means, have fun. But if your not, you could lose the program and never know it.
I say that because, if you have your ECM reflashed by technosquare (which I plan to have done as well), and you bring it in for service which requires repgrogramming of the ECM, your $500 just went bye-bye. Whatever they write onto the ROM will be removed by the deamon durring reprogramming.
10 HP for $500 is kinda high.....well, really high. I mean, durring warm up your engine makes way more than 10 HP over normal operating temperature. I'd put the money towards keeping my intake manifold cool and getting the heat away from the engine. Now if you're turbo or S/C and really need to get things cooking without restraints.....now thats when $500 will be well worth it.
Best bet, get heat wrap for your intake pipe to throttle body, box off the cone filter (if you have one) to only get fresh air from outside. Put the 06-07 Manual tranmission lower plenum in (same as 35th anniv), and a lower temperature thermostat. All that combined should give you your 10 HP without giving up your ECM for a few weeks. Even Nissan admits there is 400hp in the stock ECM (not publicly, but trust me, its there), but that is coming from the people who wrote it. If technosquare can only get 10 from it, then obviously, they need more time with the system. For custom setups though, they are VERY good. I have seen, used and been impressed with the UTEC, but its not much different the the E-Manage Ultimate and many other piggy backs. Becarefull with those too as you can cause some expensive repairs. I plan to have my base map "masaged" by technosqaure since my 240sx rides with DTC's stored all the time. But then again, I'm only doing this to help out the other guys that are putting the VQ into other cars, so they will know what works and what doesn't.
Modified by SpecDRacing at 4:52 PM 9/27/2008
