pcpower wrote:Then there's apparently a small puddle of snow/ice on the ground, and the TCS kicks in, and the engine won't rev over 2000 RPMs.
Your right, lets just let the avg driver cut the corner, nail the gas, and have wheel spin that is so bad, they can't even keep the car straight. At the same time they won't move anywhere because ALL OF THE CARS POWER is being applied to the slipping wheel. At least with TCS/VDC it allows a controlled method of power to still get to the ground and will be ready for the wheel to regain traction.
I love having VDC and ABS, it makes me feel that in a panic and emergency situation, it just may help me out.
spike228 wrote: You can't talk on the phone if you are shifting, and you can drive if you don't know how to drive stick.
If you can't talk on the phone while you drive a standard shift vehicle, then you really can't drive a standard shift vehicle! I used to have no problem shifting/wheeling with one hand/knee and holding the phone with my other.
