JUKE OWNERS: TCE has recently released three new front Big Brake Kit options for your ride!
On the least expensive scale a bolt on "Caliper Kit" for your stock rotors gets things started at only $781.
These calipers offer an inexpensive means to enhance your cars braking response, shed some unwanted pounds and spruce up its looks. Each kit includes two Dyna Pro Six Wilwood six piston calipers, brackets, pads and ss front hose kit. Installation should take about an hour with bleeding.
Second on the menu is a 13" variant of the above where TCE combines both the DP6 caliper and our own 13 x 1.10" rotors for greater thermal capacity. Designed to fit 17" and larger wheels this combo offers improvements in fade resistance, response and appearances. The 1.10" wide disc is directional cast for improved air flow, gas slotted and zinc plated. Then bolted to our aluminum rotor hat for weight savings.
Top banana; our 14" Forged Narrow Super Lite Six kit with 14 x 1.10 wide discs, FNSL6 six pot radial mount calipers and thicker, longer lasting brake pads. The 14" kit offers extended benefits over the 13" kit with yet more rotor mass and efficiency. The radial mount FNSL6 is a stout competitor proven in both street and track use. If you need that kit that 'goes to eleven' for your Juke this is the answer you've been after.
Check out these and all the great offerings at TCE today.
http://www.tceperformanceproducts.com/n ... e/kits-32/
