C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Wed Mar 14, 2007 2:22 pm
Have you looked at or ried out the extended seat? I was actually unaware there was an extended seat. I'm not sure of the exact difference myself. I would guess it isn't going to be ab add-on though. Are you sure it's not lateral thigh support?
As a suggestion, you might try making sure your left leg can reach the dead pedal with your back correctly against the seatback. Then actually use the dead pedal by bracing lightly against it. This will give a you a very well supported seating position. Using the dead pedal is actually recommended for performance driving as well as it keeps you in the seat more firmly. A proper dead pedal is not just a place to put your foot. It's actually intended to be a functional piece.
