rlmfire wrote:Those will do it. Wonder if an overlay is the only way to hide the button I won't use for the trunk? All I ever use is the key fob thingy. I'll have to find those after the lights. Don't believe the hole could be filled and look good by any plastic means I know of.
Coolness. Time to start shoppin!
Tanks again pfarmer.
Wonder what would happen if instead of filling the hole with plastic, etc. you actually use the hole for something like another light. That is you create a hole in the other side and then enlarge the stock hole and install a set of lights in both. Just a thought, haven't really looked into what this would look like but it seems like it would be do able if desired.
Perry
