The T5 will be good if you have on right off the back. What will you be putting the Transmission behind? Not sure, but more than likely you'll need a new F/W & Psi Plate.vrizi wrote:Okay,... I know that the t56 is a better trans to use compared to the t5,.... but I might just happen to have a t5 that I can use. So I think that I may start with the t5 and then upgrade later. If I do this, will the flywheel, clutch pressure plate all work when I switch from t5 to t56
