T33 engine oil pan broken...
V6er
Car: 2014 Nissan Rogue T32 SL
2023 Nissan Rogue T33 SL
a little update.
since they messed around quite a lot - next oil change was done at dealership again (if they (d)ucked up the oil pan - let them eat new oil pan price :D
after that "next oil change" - grabbed borsescope, found oil residue, went back - was forwarded to some real mechanic. had a chance to talk with him personally at the car. oil leak was at oil filter...
fast forward to today... grabbed borescope again... aaaaand....
- on that last visit it was cleaned properly with brake cleaner... even though picture is not the best - it looks to me that oil plug is leaking.
The attachment IMG_014.JPG is no longer available
and this (oil pan between oil drain plug and filter) looks like there is another leak going on... might be what @VStar650CL mentioned about another possible leak in connection with upper oil pan...
@VStar650CL, are there TSBs about upper oil pan?
anyway - one of my good friends said that I am making myself into clown with these pictures... will remove that dust cover and will make better pictures next time...
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
V6er wrote:
Sat Mar 08, 2025 9:39 am
Nope.
Frankly that doesn't look like you can really call it a leak, just some filming. Unless you find a source up higher on the engine, I doubt it's anything to worry about (although keeping an eye on it would be wise).
Return to “Rogue Forum”
