T32, MY2014, QR25DE, with intelligent key - instrument cluster identification
V6er
Car: 2014 Nissan Rogue T32 SL
2023 Nissan Rogue T33 SL
Yello!
as usually when I have too much free time - I come to FUNtastic ideas :facepalm:
like - let's get another instrument cluster and see what can (am able to) do with it. especially since there are people who have managed to use them outside the car - https://www.youtube.com/watch?v=UTwVOWjcMog , for example. but my interest is more to "get inside cluster" and do some things that were not really planned by nissan.
did a little search on ebay. there are a bunch of those for 30bucks. sounds nice.
but there is an issue: part numbers.
1) I started with nissanpartsdeal.com - it lists different part numbers for different production times. according to sticker in drivers door opening - our is 11/13.
though fun part is that nissanpartsdeal.com data starts at december of 13 :D
24810-4BA0B - Production Date: 12/2013-03/2014 - Replaced by: 24810-4BA8A - https://www.nissanpartsdeal.com/parts/n ... 4ba0b.html
24810-9TA0A - Production Date: 04/2014-09/2014 - Replaced by: 24810-9TA8A - https://www.nissanpartsdeal.com/parts/n ... 9ta0a.html
24810-4BA3A - Production Date: 09/2014-06/2016 - Replaced by: 24810-4BA8A - https://www.nissanpartsdeal.com/parts/n ... 4ba3a.html
so, I guess - this is why our Rogue is at 216kmiles and still kickin' - because it was preproduction sample done by engineers themselves? :rotfl
2) on ebay - most of "part numbers" seem to be not really part numbers.
https://www.ebay.com/itm/277731132017 - 5HA3A-YD8Y
https://www.ebay.com/itm/146403785886 - 5HA8A-WK7J, saplaisajis stikls
https://www.ebay.com/itm/146403791210 - 5HA0A-PN5S
https://www.ebay.com/itm/277575466760 - 5HR0A-GYCL
https://www.ebay.com/itm/336451773627 - 5HA3A-JL94, 0936150827
https://www.ebay.com/itm/336451773608 - 5HA3A-YKVC
https://www.ebay.com/itm/336384924185 - 5HA8A-7ISC
https://www.ebay.com/itm/376165526388 - 5HA8A-FDFX
https://www.ebay.com/itm/187805011562 - 7FM0A-1P91
https://www.ebay.com/itm/177690454190 - 7FMOA-98FR
https://www.ebay.com/itm/167619954994 - 24810-6FJ0A, 2016 NISSAN ROGUE
https://www.ebay.com/itm/187835738242 - 24810-9TA3A, CKMX-AGS
seems like that is the sticker on back of instrument panel with calibration software version?
and few more questions:
1) is it possible to program instrument cluster so that it can be switched back and forth with two, so I can "play" with their internals, but still have working car?
2) are there real known differences between clusters?
3) from the pictures on a back of instrument clusters - I see there are testpads there. is there any information on those? what signals are there, etc
4) connectors for wiring. https://prnt.sc/bdnYEjfokZth - this is picture from FSM. anybody has suggestions what are connector specs/names to get them? can they be found in parts catalog by nissan? https://static.nhtsa.gov/odi/tsbs/2020/ ... 5-0001.pdf - looks like not really viable to try to get something from nissan itself :(
V6er
40pin connector probably is Toyotas 90980-12169, 90980-12170 ...
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The connector is a Sumitomo NH series, TH40FW-NH. Nissan uses that type all over the place, including practically all their late model clusters. That makes them very easy to find in junkyards, BUT (important but), they're hellish to unpin and different models can have completely different schemes for the wire locations. You can get fully-loaded pigtails for $17 here:
https://www.aliexpress.us/item/3256806832656328.html
Tariff is covered by the vendor and shipping is pretty prompt, usually under 10 days.
Differences between the clusters on a '14 will be in the warning lamps and the firmware driving them, depending on the car's equipment list. Nissan clusters before about '21 weren't CAN-reprogrammable, so you'd need an application-specific programmer and firmware from the manufacturer to make use of the programming ports on the circuit board. The needed programmer may or may not be available to the public, but the firmware certainly won't be. The exposed port on the back is probably for manipulating the EEP or flash that stores the odo and other parameters which are configurable. Chances are there's another one inside which is used for firmware.
V6er
:clap: maaaaan! :))) THANK you!
do you happen to have part number for that other connector - 12pin - too?
VStar650CL
Technical Expert
It's the same family, TH12FW-NH. You can get that one from Nissan, p/n 24008-9DM6B, but it isn't cheap. It's also used all over the car, shifter, roof console, EPB, IPDM, spiral cable. So that one is really easy to find in JY's.
V6er
holly molly - 60bucks and that is online store... :D thanks!
VStar650CL
Technical Expert
Oh, hey... it just occurred to me that they use that same 12-pin in the standard accessory connector, 999Q9-AY000. Those are $15~20 all over the place and they're fully stuffed.
V6er
I will try to find TH12FW-NH first. because I realized that I _might_ need to do something along lines of "man-in-the-middle" "attack" .
and looking at wiring diagram - this 12pin connector is the one carrying both can busses...
that seller you gave link to - he had lovely sets of female-male connectors, but he doesn't have this TH12FW...
though seems like toyota part numbers might be used...
what do you, @VStar650CL, think about this - https://www.aliexpress.us/item/3256806960036965.html ? seems legit :D
VStar650CL
Technical Expert
I wouldn't bother with China on that. With the shipping it's $10, and you can get a clone accessory pigtail here in the 'States for the same $10.
https://www.amazon.com/Accessory-Pathfi ... B0F2H1BRYT
V6er
VStar650CL wrote:
Fri Feb 27, 2026 6:14 pm
yeah - it is cheap! :)) but now I want male and female connectors - to be able to insert can-bridge between instrument cluster and other devices (to help me with hacking/logging :))
soo... how is your crystal ball? does this seem to be the right connector? https://www.aliexpress.us/item/3256806960036965.html
oh, and what about ability to program instrument clusters to work with NATS? I recently asked you about ECU, but those are not going to work...
VStar650CL
Technical Expert
That's definitely the right connector for a M/F setup, yes. NATS is irrelevant, the cluster isn't a participant. On a gen2 the only NATS/NVIS participants are the BCM and ECM. There's no discrete IMMU (it's a dumb antenna) and the IPDM is a spectator. The only part the cluster plays is turning the red key icon on and off at the BCM's direction. The actual cluster firmware and the non-volatile parameters like the odometer won't be alterable via CAN (although you may be able to rewrite RAM parameters like the DTE and trip odos).
V6er
thanks again! :)
what I would like to achieve - are many things... it boils down to ability to edit firmware adding/removing/changing stuff. but how far will I get - I don't know... :)
VStar650CL
Technical Expert
You won't get anyplace with the CANbus. If you can identify the master chip on the circuit board, you might be able to get a programmer for it and decompile the program (assuming it isn't code-protected). If it's an ASIC then that's probably wishful thinking, but if it's a commercially-available microcontroller then maybe.
V6er
you always know how to get hopes up... and down....... :D
VStar650CL
Technical Expert
Sorry. Just don't shoot the messenger. :ohno:
Return to “Rogue Forum”
