s14kaibigan »
https://forums.nicoclub.com/s14kaibigan-u6080.html
Thu Sep 11, 2003 4:27 pm
Okay, this may be a repost, but through the many, and I mean many, posts that contain "t3" I couldn't find a definitive answer.
What is the difference between the t3 super 60 and a regular t3 .60compressor and .48turbine? Is there one? I just bought a t3 with stampings of .60 on the compressor side and .48 on the turbine side. On the compressor side it also say "M11" beside AR .60 and GARRETT in big letters. On the intake, there is an elbow that says "ford" on it and the exaust has the 5bolt elbow on it also. It's watercooled and has an integral wastegate. I hear that the Thunderbird turbo coupes has this turbo as well as a .60/.63. Being new with turbos, I don't exactly know what the trim is, I just sort of know how to read the AR for each side. Without actually feeling one run or seeing any charts, I feel this should spool pretty low (like 2700-3000), but lack anything past 6000 (which I really don't go past anyways). Am I correct to assume this?
With this turbo, I'm going to run 370cc injectors, hacked maf, walbro 255, starion fmic w/ custom pipes, custom log-style manifold without external wastegate pipe, and a manual boost controller (possible run in-cab). Being a log style manifold, I feel there isn't really an efficient location to put an external wastegate, but I've heard of people removing the integral and welding a pipe in its place to run an external. Is this possible and efficient?
Also, being a t3 and running with a starion i/c I probably wouldn't feel comfortable raising the boost past 6-7 psi due to heat and detonation. This is going to be a daily driver with some spirited fun on the weekend type setup. I'd like to get about 230rwhp.
Basically, the point of this thread is to find answers to a couple of questions I have, explain my setup/goals, and receive any insight or criticism on it also. Please let me know what you think.
