t25,t3, or t3/t4 which is better
tk240
Car: 1990 240sx
well if im wrong, im sorry i was just wondering t25 is the smallest, t3 are about the same size so which is better on a stock engine to turbo i mean doesnt a t25 have less lag?
neverlift
please do some research and come back with real questions
tk240
Car: 1990 240sx
i did a bit i mean my friend has a conquest with a t3/t4 i was just wondering cuz his has a lot of lag
WDRacing
tk240 wrote:i did a bit i mean my friend has a conquest with a t3/t4 i was just wondering cuz his has a lot of lag
HE said do some research because there are a lot of factors that play into turbo selecion. The only reason anyone ever uses a T25 is because the manifold that matches that style is only $60. But the T25 is far to small. Yes it's going to have no lag, but it's not going to make near the power that a properly sized turbo will.
The end goal for power also needs to be considered.
In short figure out what YOU want, then read through the stickies at the top of the page. After which you can come in here and ask informed questions.
WD
S13FX
Car: '69 l20b Dimeski :)
If you ask me their all excellent choices, just make sure you use gorilla glue when attaching either of those turbos to your intake manifold.
And most important of all don't forget to use high temp rtv on your injectors.
abc123omg
Car: '93 240sx KA-T
what is "better" is defined by your goals.
if you want quick spool, go with a t25/28. kicks in about 3k and has potential but not as much as it could.
t3, a lil bigger, wider usable powerband, some noticeable lag possibly
etc...
also alot has to do with the AR ratios or whichever theyre called of the turbos.but seriouisly, read up on it and google "turbo 101" or soemthing.
neverlift
a t25 kickin in at 3k not on a ka lol, my setup was boosting 11psi at 2.3k my t3 wants to hit 11(spikes) at 3, granted its a small t3 .42 and .48
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
my t25 kicks in pretty early around 2.5 and i feel like i have vtec around 6k rpm. LOL weird never did wonder why, could it be timing? maybe bad turbo. but who cares my car is gettting at least a t2871r reall soon. hope to make 400whp....the sr's can do it so i think its even easier for us.
boznuttz
Car: MS13
Like everyone is saying, it really depends on what you really want from the car. If you want to autocross and such without much power, many swear by the SR T25.
You also need to consider a turbo's effeciency. T25s from SRs really become heat pumps at higher boost levels.
