I've been changing my own oil for over 40 years every 3k-3.5k miles. No need to waste $$$ on synthetic in my opinion. Pages of pages have been written on this and other forums. I don't believe any new automobile comes with synthetic oil nor do most maufacturers recomend its use in the owners manual..Sentientbydesign wrote:You're trying to start a fight aren't you?
I'm currently running regular because that's what the engine came with .
Just curious, have you ever tried a synthetic? I'm not trying to start an argument, just curiousity.telcoman wrote:
Telcoman
Also, what speed to you cruise at on the highway? I find your fuel economy remarkable.
Find a way to get us a hook up on the Royal Purple. I hate paying $7 a qtsnwbrdr435 wrote:I use royal purple because i can get a deal through one of my friends and pay absolutely nothing for it. I will not go back to dino ever. I think telco should try the synthetic and see if he likes it. I already know the answer to that question though, 401k
Corvette's Evo's, GTR, Porsche, Ferrari, VW just to name a few come w/ synth oil. And ALL VW's 2004 and up it is reccomened in the owners manual. The Evo's oil cap says MOBIL1 in it.telcoman wrote:
Telcoman
Thanks for your correction. I'll never own any of those but its good to know anyway. I stand corrected.awdjdmtalon wrote:
I spun a rod bearing in my last car, and my machinest told me that if I had not been running synthtic oil i would have wasted the motor. Only damage was to the rod that the bearing spun in. It got hot and blued it. The crank survived.
Hahahahaha. The truth comes out!!!SVTCOBRA wrote:M1 SYN here every 3 to 4K miles.
04 Coupe AT w/44K miles gets 21 MPG 2/3 City 1/3 HW Currently riding shootgun and typing on a trip. Wifie drives faster on the boring HW than me!
C-Kwik:C-Kwik wrote:Synthetic oil are generally far superior to conventional oils. Not do they reduce friction at a wider range of temperatures and RPMs, they have much better cold start properties. Since this is wear engine wear occurs most, this is an important property. Synthetics also do a much better job of keeping the insides of your engine clean.
My own observations when removing valve covers was that motors using conventional oils have a layer of varnish all over it. On the other hand, a valve cover removed from an engine running synthetic was very clean. This includes a motor I know ran conventional oil for a significant length of time and was switched to synthetic. I prefer to know this varnish isn't forming on the more important parts of the motor as well.
Here's a good article providing a pretty basic overview of synthetic oils:
http://www.carcraft.com/techar....html
You can run a search on google for much more technical info. This stuff isn't snake oil guys. Even with shorter maintenance intervals, synthetics simply have a big advantage over conventional.
As a side note, Costco sells a case of Mobil1 for a few bucks cheaper than you might find at the auto parts store.
I also raid the Walmart when they put the jugs of M1 on sale for around $20....usually get 5 or 6 jugs at a time.Sentientbydesign wrote:Walmart sells the 5 gallon jug of M1 for under $25 IIRC. Costco also has a good price.
5 gallons or 5 quarts? 5 gallons is enough for like 4 changes. Not to mention trying to pour 5 quarts of oil out of a bootle the size of a bottle that sits atop most water coolers...Sentientbydesign wrote:Walmart sells the 5 gallon jug of M1 for under $25 IIRC. Costco also has a good price.
