Synthetic oil or regular oil
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
leecar83
As the post above said, the only fully synthetic Castrol is the 0w-30 imported from Germany. It is an excellent oil and regularly returns superior oil analysis results than does Mobil 1 or Pennzoil Platinum on http://www.bobistheoilguy.com. In fact it has its own forum. All of the other grades of Castrol are overpriced. BTW I use German Castrol in all my vehicles
fjwagner
Car: 2008 Nissan Versa S et al
Coincidentally there is a TEch Talk response in this month's BMW Car Club magazine that states emphatically that synthetic oil does not cause leaks. I do not have a scanner, but will have my secretary scan it so I can post this evening. Fred
Driving Instructor
Car: 2007 nissan versa SL CVT Red
Oh..does that mean I got ripped. I did buy Castrol Fully Synthetic oil in Canada. 5W30
SpeedyV09
Car: 08 Versa SL Black
I have a question still on the same topic but does it make a difference if you use conventional or synthetic in a manual 6 speed Versa transmission. I remember reading somewhere that it will run a lot smoother and changing gears as well is a lot smoother, is this true or not??
NewToVersa
According to many web forums, it's true. But you have to get the right kind.
fjwagner
thatguy1234 wrote:I have a question still on the same topic but does it make a difference if you use conventional or synthetic in a manual 6 speed Versa transmission. I remember reading somewhere that it will run a lot smoother and changing gears as well is a lot smoother, is this true or not??
Your transmission oil is what impacts your shifting, not the engine oil. This thread has been about engine oil.
Return to “Versa Technical Discussions”
