Elmojo »
https://forums.nicoclub.com/elmojo-u45146.html
Wed Mar 12, 2008 3:05 pm
Hi all,
It's been a looong time since I've been around here, mostly with work keeping me busy and because my V hasn't given any trouble!
However, I have some news that might be of interest...A while back, I posted some info regarding replacing the fluid in the 6MT with a full synthetic produced by Redline Oil, Inc.If you care to read the "history", search this board for "elmojo" + "redline".The gist of the matter is that I had several discussions with the service tech at my dealership, reps from Redline Oil, and even Nissan North America Engineering.I came to the conclusion that synthetic MT fluid would be a possible remedy to the horrible clunkiness that is the Nissan/Renault 6MT used in the Versa.However, I was hesitant to make the switch due to receiving a call-back from Nissan Engineering, informing me that switching to a non-Nissan fluid would "probably" void my warranty.
Since then, I put up with the poor shifting while 4 quarts of Redline MTL sat in my shop. Recently, I decided to rethink this issue.
I contacted Redline and had a detailed conversation with one of their "shop guys" about the product and possible warranty issues.Long story short(er), he said that since the MTL fluid meets all the requirements and certifications required by Nissan, there would really be no way for the warranty to be voided by the use of Redline MTL.Armed with this bit of reassurance, I decided to take the plunge and have the transaxle fluid changed at my last service.My dealer charged me $70 for a "standard transmission service", and I provided the fluid.Nissan says the fluid change requires 4.25 pints. Yes, pints, not quarts!3 quarts of fluid is what you need.
Results:I can't begin to tell you how much better this is!After about 300 miles on the new fluid, I'm estimating about a 30-40% reduction in shifting effort, and about the same increase in smoothness.Oddly, the most drastic change in noted under normal, low-load shifts.Hard driving is still difficult due to the overall lack of refinement in the gearbox, the long throws of the shifter, and the annoying RPM hangs between gears.For everyday driving, though, this has been the best 100-ish bucks I've spent on the car yet.Highly recommended!Keep in mind, Nissan is still claiming possible warranty issues when using this or any non-OEM fluid, so use at your own risk.
