jltibbs »
https://forums.nicoclub.com/jltibbs-u32412.html
Thu Dec 28, 2006 6:46 pm
right in front of yout consloe there are 3 coin holders, makes a great spot for toggles. i would highly recomend getting factory foglights instead of aftermarket. if you go with aftermarket you should get a factory headlight switch with the foglight option on it. that way you can add the foglight relay to your fuse box and tap in to your factory wires for the foglights and not have to worry about running the extra toggle. most, if not all, A32's have the foglight wiring from the factory, of course not all came with fogs. just my $.02
