Sway bars and exhaust
Anand
Car: 95 Nissan 240SX
would it be ok if I got the sway bars!?!?! or do you guys think I would have problem with my dual N1's??
damnthecops
Car: 1989 Nissan 240sx Coupe
iv read that the dual n1 gets in the way of the sway bar.... but im not sure cause i hvnt put on either yet
Anand
K-car... help me out with this with your vast knowledge!!!!
MaineExport
Car: 95 Nissan 240SX FAL fans AEM intake Hot Shot header Apexi N1 dual Exhaust VLSD ABS NX 50 shot
There should be no problem with the stock rear anti-sway bar fitting properly. I have only heard about a problem with the whiteline sways fitting poorly with the N1 dual.
I'd judt go to a junkyard and buy the factory sway bar off an SE.
This is on the s14 right?
Anand
I figured, you might have known K-car... oo well..yea, main.. it's a S14. thankx for the help.. I'll go check on it.
Exar-Kun
Car: 2005 350Z
ST sway bars have problems clearing the dual N-1. I would assume whitelines do too.
either way, you may be able to shim them or something to get them to work properly...-chet
R240NA
There is a clearance problem, but it's very minimal. A good friend of mine runs an N1 dual with the ST bar, just used a piece of heat warp around the bar to keep it from rattling.
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
yeah, only problem i heard of them having was that the exhaust and bar kept hitting each other while driving, especially in turns, making an obnoxcious noise.
R24ONA...did the heat wrap around the bar take car of all the noise issues?
-Dan
R240NA
Yes, it's fine. You could even wrap rubber hosing under the heatwrap first.
Exar-Kun
Car: 2005 350Z
wouldnt that melt given the exhaust systems high temperature?-chet
R240NA
Nope. Underneath the heat wrap it's insulated, plus by the time it hits the swaybar it's much cooler than the manifold. Hangers are rubber, but they don't melt. Ah ha! Damn I feel silly today.
