VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Wed Feb 10, 2021 8:19 am
In the course of repairing the damaged rear suspension on a '15 SR, I noticed that the part number for the rear sway bar had a Maxima suffix -4RA0A. Doing some research, I discovered that the Max sway bar is a plug-and-play upgrade for any gen5 Altie just by swapping the bar and bushings, no other parts needed. The links and clamps are identical, and in fact the SR's from '15~'18 all use the Max bar as standard equipment. It's a major upgrade, the Max bar is nearly twice the diameter of the weenie standard bar.
Found a used bar off a '17 Max for $75 on eBay and installed it on the wife's '13 SL this weekend. OMG it's a different car! No more "setting up the rear" when entering a high speed sweeper, she's totally point-and-shoot. I don't think I could induce a fishtail if I wanted to.
The bar from any current generation Maxima will work, 56230-4RA0A or -4RA0B. The bushing part number is 56243-4RA0A (same part left/right). I notice a lot of people spending big bucks on Stillen bars (and they're great, I've driven one with a Stillen upgrade), but you can get the same results for a fraction of the price by using the Maxima bar.
