slownslurious »
https://forums.nicoclub.com/slownslurious-u29303.html
Thu Jun 02, 2005 4:16 pm
it took me 4 full days to swap, including everything (piping, wiring, etc). I worked on it during the day and had friends help at night.I did not upgrade or replace any parts except the spark plugs, because they were horribly fouled. My total cost for the engine, spark plugs, wiring, downpipe, turbo outlet, etc, was somewhere around $1300-$1400. I'd defintely say that if time is an issue you should have a couple hundred bucks ready to spend at the parts store for when things go wrong during the install. Having pulled various motors in and out of s13's for the past few years, I think that with mechanically inclined help, the swap could be done in a weekend. This would be pushing it to the bare edge, however, and I have found that work done while you are tired or hurt is not quality work and you'll probably **** something up, and since you haven't left yourself enough time to test everything out and make repairs where necessary its more likely that something will break and leave you stranded... just my two cents.btw I drive mine everyday, aside from having problems keeping coilpacks on the motor I have no problem driving it every day or taking it for long trips.
also I should point out that I bought a motorset with EVERYTHING down to the turbo inlet, air filter, intercooler, piping, resistor boxes, etc... and I would say that if your motorset or clip was missing these parts it could easily double the cost of the swap and triple the time. ca18 parts can be hard to find and expensive to obtain, and slow in shipping... etc... and though some parts are interchangeable with usdm cars, finding those cars in salvage yards is not easy, and even finding replacement parts for obscure cars like pulsars can take a lot of time and money. Its a LOT better to buy one with everything you need. I know everyone says that, but look at what the people above you are saying... it took them a lot longer, was more expensive and more difficult because they didn't have what they needed.
Modified by slownslurious at 7:30 PM 6/2/2005
