Suspension Upgrades
StockMuffinSE
Car: 2002 Nissan Maxima SE 6-Speed
My roomate drives an 04' G35 sedan. He is currently buying 350z shocks and springs for the car. He has informed me that it is a direct bolt on and is what lots of G35 drivers do for a cheap performance fix.
Which raises my question....Is the 350z suspension a direct bolt-on for an 02 maxima se? Im afraid I will probably have to go with an aftermarket setup. Any information would be appreciated!
dan
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
Said it before and I'm saying it again, Eibach pro kit with Tokico Illumina struts. Can't go wrong with that combo!
Add a FSTB (front strut tower brace) and a RSB (rear sway bar) and you'll be set!
nismo1219
Car: '12 Nissan Altima 3.5SR
'99 Nissan Maxima GLE
AMEN to that brother beancooker! noah is a wise, wise man, and his advice shuld be thought over. i listened and went with the eibach prokit, illuminas, fstb, and rsb....much improved over stock! i would def. recommend this setup for anyone doing a suspension upgrade!!!
00MaxSE
Car: 2000 Nissan Maxima SE 5MT
I'm on Illuminas and Progress springs with the FSTB and RSB. You'll get a bigger drop than with the Eibachs, but the ride is a bit stiffer. H&R's are also a good alternative.
audtatious
I highly doubt the 350Z's RWD suspension layout would work at all with a 2k2 Maxima.
As the above have stated is the appropriate path.
[email protected]
Car: 2002 NISSAN MAXIMA SE
YOU GOTTA CLEAN MAX
