NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sat Dec 20, 2003 10:13 pm
check your suspension arms attached to the axle housing. I have come across quite a few pathfinders and qx4's with torn mount bushings in those arms. you can purchase those bushings seperately but I dont recommend it due to every one we have tried to just replace those bushings alone on was unsuccessful. they are pressed in and do not want to come out. we were successful on 1 set of 5 we tried. the last set we did we attempted to have a machine shop do the press work for us. they did some serious damage to the arms doing it. so in the end we put all new arm on it. The reason we continued trying to do it that way so many times is because it is much cheaper for the bushings then the whole arm so we were trying to save the customer some cash doing it that way. The last set is the last one we will ever try to do. From then on we only recommended the entire arms. I have done the repair for that problem my self approx 20 times. other techs in my shop have also performed that repair several times.
Have all 8 of those bushings inspected closely for cracking,tearing,or shifting on thier pin. you will mostlikely find this is you problem. I would geuss you also get the feeling the car is shifting to one side when accelerating?
