Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri Dec 26, 2003 2:36 pm
Once elevated on a lift and after wheels removed takes 5-15 minutes each depending on wrenches and air tool assist.........roughly the same as the tension rods.
Changed the left one yesterday to fix a cold squeek, now my right king pin bearings are shot again [wheel tire top/bottom moves in/out] after only 22,000 miles. Something else must be worn like the kingpin seat/kingpin to cause this fast wear.
It's always something every year [20k].Only 2 years [40k] to go to reach 300,000 miles.
This year: 4 shocks and boots, transmission mount, upper links and tension rods, fuel pump, all brake calipers & pads and 2 rotors, spark plugs, a battery, a speaker amp, headlights and all bulbs, misc...........close to $2400 in wholesale parts [30% discounted] alone.
