Definitely a great way to gain lift (and quite a lot at that) I stacked springs on my ford, which improved height, handling, and weight capacity big time. Supposedly s10 springs have huge arch as they are setup for spring-under, and even the 620's in my yard have more arch than my (still, even with an add-a-leaf) flat rear springs. I'd have tackled them again already but for the problem trying to find the spring center bolt at ANY of the local parts stores. Try it! lol, I got the same dumb look at every one. Suppose I am the idiot however for realizing now I should have gone to any one of the aftermarket or spring shops in town. Anyway.
The only difference between the spring center bolt and a regular bolt from a hardware store is the head of the bolt is round like an allen bolt and the hole in the spring pad on the axle lines right up with it. If all else failed I was just going to grind down the head of a grade 8 bolt to fit.
Here we go
https://www.4x4parts.com/nissan/center- ... -5632.html
Definitely plan to buy new spring to axle ubolts, shackle bolts, w/e they are called, as they are 25 years old and will most likely break on you, and if they don't, it's still a cheap precaution to losing your rear axle somewhere down the highway doing 60mph. I've seen it, it isn't pretty =(
I'll post again when I pull the parts together for this. I've seen guys drill holes into the leaf ends and install zerk fittings--messy, yet effective. Need to find a source to get teflon inserts. This weekend, or the weekend of the 18th for sure I'll post up the whole project. (poly bushings, extra leaves, 2inch shackle lift, and overloads.)
