rmlamp »
https://forums.nicoclub.com/rmlamp-u261126.html
Fri Jun 24, 2016 10:20 am
The cost is definitely not bad if that's what you're looking to do but it always costs more than you initially think. As someone else said, is that S/C going to have enough flow for a VG? You're going to be putting in countless hours trying to figure this thing out with no guarantee that it will even work. Keep in mind all the supporting mods that would go into this. Gauges (ARF and boost at minimum), fuel injectors, fuel pump and all the odds and ends you will need, which always, always is more than you ever thought possible. What happens if you put in hours on end and blow the motor a month later? Or what if you have only a small increase in power? I'm not saying its not possible, I'm just saying its not very practical. Like I said, I picked up my TT for $1100 and it has a new set of turbos on it.
It also depends what your goals for the car are. If you're looking for low 300 hp, maybe your plan is feasible but in my opinion it'll be a ticking time bomb unless you never push the boost. I bought the car with plans to rebuild the motor, fully forge and upgrade turbos with hopes of seeing low 700 hp. Evaluate your goals and thoroughly think this out and have a plan. Also realize that odds are against you and boosting a NA is very risky. It would be hard for me to justify the amount of hours needed to pull this off for the amount of unknowns included.
Like I said, don't let me talk out of this if its something you're dead set on. Just realize there will be a lot of fabrication, reworking of plans, frustration and it's all for a maybe. If you're pulling the motor, theoretically, you could throw a used set of TT pistons in and the compression problem would be a thing of the past. In fact, before I found my TT, that was my plan. I have a set of TT pistons and wrist pins if you're interested.
