Crazyirish wrote:
I thought lag was generally defined as the delay between throttle input and boost being built. If this is the case then a centrifugal would have no lag as the boost they produce is a direct product of engine rpm.
I have seem this statement made many times and have never understood the reasoning. Am I missing something?
crzycav86 wrote:You're right.
To make such a generalized statement like that shows a lack of understanding.
I don't know who you guys are referring to when it comes to lack of understanding...but it sure as hell isn't me.
Lag and boost threshold are terms generally reserved for turbo's so we can choose trim and AR size. Things generally NOT used when discussing a supercharger.
But since you two can't seem to fathom why a centrifugal SC is termed laggy...allow me to explain it for you.
How would you like to hit full boost when you max out your rpms? Cause that's what you get when you choose centrifugal. AND that is the ultimate meaning of lag IMO.
A turbo does not respond like this, a roots style SC does not respond like this...so what you get IS the worst of both worlds. It gives the motor paracitic loss and suffers from lag. If you don't get it
Does it provide some boost from the get go...sure. But it's already robbing you of horse power just to break even. So yes, lag is what you get.
Is that explained enough well enough?
WD
