Supercharged KA build
ss82480
Car: 1992 240sx Coupe
Ok here is the scoop. The car was running LEAN as hell when I first got it to the dyno, close to 17:1 af ratios at WOT. It first dynod 166whp, then they added +20% fuel across the board with the safc and hit 198whp. They tried upping it more but the numbers went back down. About this time I realized that I originally planned on low boost, which meant I was ok running stock fuel pump. Since on a whim I decided to up the boost, I absolutely overlooked my fuel pump needing an upgrade.
Needless to say after a little leaning out on the new fuel pump with the safc the first solid run was about 211whp with 200wtq. The following dynos the a/f ratio was tweaked but the peak power remained about the same, due to heatsoak. I got video and dyno charts that I should be able to get up by tomorrow.
Modified by ss82480 at 7:32 PM 2/7/2009
s14derrick
Car: 1995 nissan 240sx
200+ whp and tq?sounds like a fun *** car !any other planned power adders?
ss82480
At this point I am just going to add things to keep it running good. Down the road I might consider meth injection, a bigger throttle body, or getting the cams degreed in.
simmode1
Car: Red '95 S14
This is beastly! I just heard about this thread. I can't wait to see this car!It's good to know DFW's local 240 scene is becoming so diverse!
zismo02
Car: S14
Nice setup!!!!!!!
I haven't seen any SC KA's or 240's matter of fact.
But, you should def hop on a EMS.Because my boy had a SOHC KA-T with a T3 super 60. He put down @ 7psi 210 /235Ft-bs.
I know they're totally different, but I think you could make more power with you setup.
addisonblck
Car: 93 se mods soon to come
Sc300 1jz swap laundry list of goodies
im not worthy ....
thanx man it looks awesome!!!
ss82480
Thanks for the comments guys, it definitely took more work per horsepower than a turbo kit, but I think it was worth it just to try something different. I think I might be getting spark blowout a bit too, which could have hurt my dyno a bit but I'll have to change my plugs out and see what results I get.
WDRacing
Just decrease the gap a little. I start at .035 and work my way down until I don't get blowout. Although I don't think you should have any blowout at your boost level. Never decrease it shorter then .028 IMO. If at that point you are still having issues, you need a better coil or more voltage.
WD
ppctx
Car: 93 ka24de-t
kick'n build... I got to get a ride in it this weekend
XMSducksauce
Car: 1996 Nissan 240SX SE
turbonola wrote:ok so i tried to make a drawing of what i was saying
This picture = win
LovesBigTurbos
Car: VW Gti T3/T4 Turbo, 03 350z sold
sick build looks sick hahha never enough power!!!
ss82480
Sorry it took so long to get these up, but here is the dyno for it. Criticism welcome, I am still looking to squeeze out a few more hps, but consider this is with quite a bit of heatsoak at 85 degrees ambient.
LovesBigTurbos
nice pretty solid numbers
Darchangl
Car: 95 240sx Ka-t (in progress)
I get to whore out his videos!! (my fault why it took so long to post them, sorry )http://www.youtube.com/watch?v=PpXWkSx2 ... N3c_BkQ89M
Jay97240Sx
Car: 97 240SX Ka-T
99 Q45T
Sweet dude, really sweet. Love the supercharger whine
AJxr
how much boost where you running when dynoed? safc tuned like as stated?
car and setup are clean!
WDRacing
I think you should toss the stock cams in and dyno it again for a comparison.
240cp
Car: 95 240sx
Man i didnt realize how much i missed that sound till now . Nice vids sounds great. Pretty nice number for low boost. I agree with wd, put back in the stock cams, i bet boost goes up and maybe power
ss82480
I will keep that in mind about changing the cams, it has already crossed my mind since I hear mixed reviews on the BC cams. It was at 9psi on the dyno, and yes was fine tuned with a safcII.
BoostFab
Car: S13cp, S13fb, S14z
nice to actually see it in person last night; when I was at the track with Aaron.
a friend of mine said the BC cams are copies of someone's else, and they have becoming less consistent, but that's just rumors.
sil_eighty86
Car: 92 Hatch, 95 240sx se
Just picked up the same kit for $700 with supercharger. I will start my own thread but I wanted to say thanks for the inspiration.
gingerbredman
Car: 93 SE hatch, ~260k miles on the clock, 15" Enkei 92s, still stock. 2009 Sonata bouncing on Eibachs.
AH loved the vids! Awesome man, hey where did you have those BC cams dialed in on the sprockets? stock positions or otherwise?
Yeah, I'm thinking with a supercharger setup, stock cams would probably be more efficient, without port work and such. Since the supercharger's powerband is broader than that of a typical turbo'd ka.
Sounds awesome, can we get some vids of it on the street, or track???
a_ahmed
Car: 1991 240sx fastback
I was gona say we need street/highway/track videos now!!!
turbonola
Car: 91 240sx coupe
now we gotta get someone to whipplecharge a 240
airman86
or kenne bell
HOMEMADE240SXTURBO
Car: 1989 NISSAN 240SX KA24E
can you please post a link or website to every or most part you bought to put the kit together? it will really helps us in the future.
ss82480
I bought the adapter plates from Thomas Knight and the s/c from ebay. Theres alot of custom fabbed stuff as well.
The best I could get at the track is a 9.1 in the 1/8th, was hoping for better. Maybe I should get serious about tuning the cams and maybe some kind of cooling. It heatsoaks so much that my times get slower as the day goes on.
Shift_Kouki
Car: 95 Nissan 240SX SE
What about switching to a different fuel like E85 for cooler burn / charge cooling?
sorrowfulkiller
Shift_Kouki wrote:What about switching to a different fuel like E85 for cooler burn / charge cooling?
E85 + Water Methanol Injection = Teh Win
OP you should save up for a whipple twinscrew once you get this thing dialed in... that would be sick as hell!
ss82480
Been running strong for 8 months, an updated picture of the setup.
