Super stuck bolt!
zxFarside
Car: 94 300zx TT (sold)
03 Suburban 5.3
00 BMW 323
Working on the drive shaft there is a support bar of some sort, 17mm bolt.This mother f***** is super stuck. I must have been working on it for 3 hours with no give, gave it maybe half a can of PB Blaster. I'm just letting it soak atm but is there any trick to get bolts unstuck. I tried a breaker bar and it broke my 17mm socket lol.
Any hits would be awesome!
pete-flint
Car: R33 Skyline GTR JDM. 300ZX (Z32)Fairlady JDM.
Can you get any heat on the nut ? Either a blow torch or cutting/ welding torch ? Look out for fuel lines etc.
zxFarside
03 Suburban 5.3
00 BMW 323
I was looking for my torch but I gave up because its snowing really hard now. I'll get to it in the morning. I wish I could just cut it off lol
NolimitZ32
If its a bolt, then cut the head off, drill the bolt through and mangle the f***er out, ive had to do it a few times on the z and the wrx. if its a nut on a stud then cut into the side parallel to the stud, be careful not to cut into the thread, once there is very little metal until you hit the thread, stick a chisel in there and hammer the f***er off.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
take it to a shop wiht a decent impact, I assume you are addressing the carrier bearings bolts, and if you are converting to 1 piece you can simply cut the bearing out
300freekzx
Car: 1990 300zx N/A, 1992 Honda Accord LX , 1991 Honda Accord LX, 2006 M35 Sport
Yeah don't piss arund with it here is the result of my last super stuck bolt. Impact guns do not always work.
zxFarside
03 Suburban 5.3
00 BMW 323
I got it off with a propane torch, 17mm box-end wrench and a mini sledge.
evildky
06 Nissan 350Z GT
yours was a plug, his si a bolt, if he smaps the head off ten the carrier bearing can be removed
pete-flint
zxFarside wrote:I got it off with a propane torch, 17mm box-end wrench and a mini sledge.
Nice touch, patience is a virtue.
dantesdoom
Car: 1991 Nissan 300zx N/A
1997 Nissan Pickup
when you say a propane torch...you talking about one of those attachments that goes onto the little propane cylinders....i just wanted to know for future reference if that would be hot enough
Geronimo77
Car: 1990 Nissan 300zx Twin Turbo
Nice work
