you put 87 in your bike???joe603 wrote:I noticed that too with my sport bike...using premium gas got WAY worse gas mileage. Turns out the manual recommended 87!? After I did the switch, I got an additional 5 mpg. Now the G35, thats different...but only with the rev-UP engine. If you have an auto, thats different.
Yup, I had an 02 Honda Interceptor...manual said to use 87. I tried premium, and got crappy gas milage...switched to skunk gas, and she ran better!infinititech1 wrote:
how old was that buddy's Z? when was the last time points were used...?gjohnson66 wrote:I've also had a buddy who ran his Z on 87 octane (I know, not exactly the same but bear with me) and he ended up shortening the life of his points and plugs. They came out looking rather coroded. In the long run, it's a small repair but (and I don't know about you) I'd rather not perform any repairs before I really have to.
As stated before, it's your car and you can do with it what you want, but it really can't live up to it's potential using sub-standard fuel.
high octane fuel does not necessarily equate to high quality...it only equates to high octane.Crashtest77 wrote:Easy to do....ferrari = high octane fuel....you will see hp ratings and most of the times in the tuner mags,they will even tell you, done on 93 octane,or some skylines before they are brought over run on 103 octane or 101. High performance car, better fuel, it's easy. The ecu will adjust everything for it to run on that, but you won't get the numbers that they got when rating it. Not to mention it burns better,so yes,in fact it's better for your car. I'm sure alot of folks remember this ...G.I.G.O ....garbage in, garbage out......i'd never use 87 in my bike when I had it, always 93.... very easy folks.......93 octane for performance....and less gass mileage.....the lower grades cuts back on your performance but gives better gas mileage your call.
some, but not all. advanvces in electronic controls/sensors, engine combustion chamber design, and so forth, do allow many engines to accept anything above 86 octane...and make a little more hp/torque when high octane is used. but, many still do not. for example, my '05 f150 recommends 87 octane. it even explicity says in the owner's manual you are wasting money by using high octane because there is no performance benefit.Crashtest77 wrote:All vehicles can take advantage of it. You will get slightly higher hp numbers.
uh, but you said that ALL vehicles benefit from using high octane...that is NOT true!Crashtest77 wrote:Haha redhead,it's a good thing we aren't talking about pickups though. We are talking about sports cars with engines that were meant to use this. The gains you see won't be on any car til you are normally wot anyway. The pressure in the manifold and the compression of these cars meant to use the higher octane gas will then be able to use the higher octane to the full potential,so no,if you aren't going to be using your engine like that,yes it is a waste,I however did not buy a coupe to sit in the far right hand lane.
no, i give up. you are the one that introduced ALL vehicles into this discussion on high octane and it's benefits. from what i know about engine/ignition and fuel system design, i've never seen anything that suggests an engine optimized to run on 87 octane gets any benefit from burning high octane, whether it's idling or running at WOT...Crashtest77 wrote:I give up redhead, you are right. All cars can use the premium gas,and yes,all cars will get a little bit more power, but that's at wot. So no,of your f150 it's pointless,but we aren't talking about your f150. We are talking about sports cars.
