Handi_Mike wrote: ↑Fri Sep 15, 2017 9:48 am
First off, the rb25 and re5r that is coming in my car, same engine trans as the r33 or an earlier rendition of the two?
I believe it will be an S1, you can tell by looking at the CAS.
is it possible to do a simple r33 lsd swap into the 32 assuming the trans is the same?
LSD doesn't have anything to do with the trans
I've also come across a couple threads of some seriously modified auto's to handle massive power. Will a stock trans with an upgraded converter hold on to 300 or so whp?
In my experience no, but I've only messed around with 1 auto RB
What does everyone do about tuning when having an auto? I assume in these the ecu/TCU are one unit? Guessing that kills the possibility of using a haltech or some standalone?
TCU is separate. Stand alone can still be used with an auto trans.
last Q! Yes or no, the gtr front bumper fits right up? I've seen both yes and no answers. Some say you need the fenders others say it fits right on the gts.
From what I know, yes it is a bolt on affair.
