I fixed the misfires. Needed 1 coil. 1 spark plug. And an injector (yes I pulled the plenum. The hoses are a b****. I did do the coolant hose bypass.
I pulled the broken pieces off the convertible frame and had them welded. Convertible now operates smoothly
I found that the coolant reservoir was cracked and was leaking.. I bought a used one on eBay and installed it... Now it doesn't get hot anymore
The reason why I'm posting today is to ask the experts about a problem I think I am having.
The acceleration seems sluggish. From a stop it doesn't seem to have the power I would expect from a v6. At high RPM the engine is strong but from a stop seems rather sluggish.
Are there any common problems like maybe a throttle position sensor or MAP sensor? Any help would be very !much appreciated.
