NolimitZ32 »
https://forums.nicoclub.com/nolimitz32-u100070.html
Fri Apr 10, 2015 12:23 pm
Is the subharness connected to the sensor itself? the ECU harness plug for the knock sensor is on the portion of the ECU harness that snakes between the engine and firewall, it will be somewhere next to the IACV where the coil and injector wires run under the balance tube.
