bdijanni »
https://forums.nicoclub.com/bdijanni-u64454.html
Thu May 24, 2007 2:34 pm
Ok, I posted a couple of weeks ago about my stubling problems. I have read through everything on here and I can not figure out what to try next. I have a 1999 q45, with 101K great condition. When you drive the car it will have a weird slight stumble, sitting at a stop in drive you the brakes on, also with do it while driving and in park, sometimes when driving around 35-45 and trying to hold the car steady between those speeds it will stumble so bad that it will act like its not going to accelerate. you have to kind of let off the gas and hit it kind of hard to get it to go. it will also do it while in park, it will sit there and just stumble really bad, almost feels like a miss fire, The problem will happen alot worse with the AC on. The AC almost guarante's that it will make it happen.
Ok so what i've already tried: I did a full tune up. a can of bg44k.the used to have the check engine light on, when i got that checked out the parts store told me that it was saying that the right bank o2 sensor and the right bank knock sensor. Well I went and changed out the upstream o2 sensors which made the light turn off and it hasnt come back on yet its been about 300 miles since then, also made the stumbling happen alot less. but is still happening. especially with the AC.
Has anyone had this problem before and figured it out?? I read in some of the old threads where people were having simular problems, they tried all kinds of different things and no one ever reported the fix? Any help would be greatly appreciated... Thanks in advance
