Strong gas smell, KNOCK SENSOR?
HOST
Car: 1993 300ZX N/A [SOLD] 1992 300ZX 2+2 [SOLD] 1992 300ZX N/A [TT Project]
I was just wondering if the knock sensor would cause a gas leak or anything remotely close to that, I was told that it was a bad knock sensor, but I'm thinking fuel pump/filter leak? I also noticed some light smoke from the back of my engine after driving a little hard to diagnose the clutch, thinking that's maybe a small oil leak from the seal? Anyone have any suggestions?
[EDIT: Didn't mean to double post for same issue, lock please..]
Modified by HOST at 11:57 PM 1/2/2010
emiliog2276
Car: 1990 300zx 2+2 NA
2002 Nissan Sentra GXE
The ECU would let you know if you have a bad knock sensor. It's Code 34. Is your check engine light on?
HOST
emiliog2276 wrote:The ECU would let you know if you have a bad knock sensor. It's Code 34. Is your check engine light on?
Nope, no check engine light. Found out hwy I smell gas btw.. I have two fuel leaks. one is the hose on the bottom of the fuel damper, and the other is the Bastard Hose from Hell, under the throttle cables. YAY!
emiliog2276
You gotta take care out that before your Z ends up in smoke. Pulling the Plenum isn't that bad though i did it for the 1st time yesterday and it only took 2 1/2 hours.
