I'm having an odd, intermittent problem with my 2011 M56S and thought I'd see if any of ya'll have any suggestions. See below for details, and if you have thoughts chime in. I'm very puzzled, so even crazy ideas are welcome!
Details:
Note: Car is daily driver. commute to work M-F is ~10 miles each way. The smart key is not anywhere near the car when it is parked (>50 feet away at home and >100 feet at office, other locations listed below). I did check out this thread but didn't see anything directly on point (
car-not-starting-due-to-a-dead-battery- ... 00121.html).
problem began in February/March, car had to be jump started a couple of times. didn't think too much of it initially, just thought I was somehow leaving headlights on or something, even though headlights are always on auto setting. After being jumped car would run fine for a few weeks before problem occurred again
reported problem when car was in for oil change earlier this year. Dealer (Peninsula Infiniti) checked battery and said it was fine.
Problem re-occured in mid-May, after driving 10 minutes to grocery store car had to be jump started after being parked for ~10 minutes. Jump starting was very difficult, other car had to be rev'd very high for a while before the M56 would start. After this incident, driver's side window would no longer roll up automatically, so it lost that bit of programming since auto-up is not the default setting for the car
Problem then occurred again Monday June 1 at lunchtime. Drove 3 miles to lunch spot, spent 20-30 minutes eating, car wouldn't start afterwards. Jump starting was slightly difficult but car did eventually start. Drove back to work 3 miles, parked, and after work car started fine.
Car also started fine Tuesday morning (twice), while driving to lunch on Tuesday, driving home Tuesday evening, and then driving to work Wednesday morning.
Wednesday evening, car wouldn't start after driving 10 miles and then parking for 5 minutes. Jump starting was VERY difficult, but eventually car started after being hooked to other car for ~10 minutes. Drove car 90 feet (to get out of road and backed into a parking space. Went to event for 1 hour, came out, and car started up immediately. Drove home 4 miles.
Thursday morning (today) car wouldn't start. Hooked to battery charger, showed 48% charge, after 1 hour charging car started right up and drove to work.
